FrankoCamp
#1 Posted : Tuesday, April 7, 2009 3:21:05 PM(UTC)
FrankoCamp
I posted 4 days ago and got ans.
bought a used Kenmoore washer Model 110 Heavy Duty 70 Series
I laid it down in bed of pick up and it leaked some oil And when I hooked it up it kicked my breacker and smoked real bad {white lite Blue|
When I fixed breake and pluged it back up It madr a whinning sound little bit of smoke and kicked breaker
tnks
Now know I screwed up when I ran wire {220} from inside Trailer to the shed where I put washer and mixed up the wires and had one of hot wires go to ground and burnt up something Now i have the wire right and pluged up machine It make3s a whinning and a clicking sound and kicks breaker . When i took every thing out of machine it did go thru the cycles and pumped slow and made the noise ,\Did I burn up the motor ,the clutch , the transmission or capactor.
Any help I can get, Thank you
frank
sidfink43
#2 Posted : Tuesday, April 7, 2009 4:58:49 PM(UTC)
sidfink43
Uh, Frank
Since you did not electrocute yourself (which was a very real possibility) I think you can consider the installation a succes). You came very close to winning a Darwin Award.
On a very serious note you should disconnect this machine (first disconnect power at the breaker to the outlet for the machine) put the machine back in your truck and take it to the nearest scrap metal recycling place, where you should get somewhere between $5 and $10.
I know you may consider this a loss, but you life plus $10.00 plus the learning experience is a pretty good deal given what you did.
Good luck
