I am looking for a part for my refrigerator that Appliance Pros can't seem to locate. My refrigerator has the freezer on the bottom. The bottom shelf is a glass piece inside a plastic frame. This piece holds the two drawers for fruits/vegetables and then the deli drawer is underneath that. The part that I am looking for and what I need is the little plastic clip that holds the frame that is around the glass piece to the metal shelving piece that is attached to the back of the refrigerator. There are two of these with the type of refrigerator, one on the left, one on the right. If I were to describe this piece even further, it would be the equivalent of the little metal clips that hold the shelves in place on adjustable shelving. Any help would be greatly appreciated! Thank you so much! Charlotte from Nebraska
THIS FORUM IS DEAD!!!!!!! |
Hi Denman,
I do not think this is the part. According to this part, it looks like it is for the wire basket in the freezer. The clip I need is at the back inside of the refrigerator that holds the flat shelf (with the drawers attached to it) to the back metal holder at the back of the refrigerator. Any other suggestions?
Thanks! Charlotte
I think Item 21 is in the fresh food section.
It is above Item 19 which is listed as a Right Hand Crisper Support which is in the fresh food section so it also has to be in the fresh food section.
Also if you follow the dotted line from Item 21 it goes to the metal shelf holder at the back of the fresh food section.
The freezer basket etc. is shown in the "Interior cabinet & freezer shelving" section.
If it is not the correct part then I am afraid I am stumped. |
Hi Denman,
Can you give me the part number? For whatever reason, I simply cannot find what you are talking about. It sounds like you may have located the right part but darned if I can find it on the list.
Rank: Administration
Groups: Administrators
Gentlemen,
I believe you two (Denman and Adam) may just be geniuses! I looked at the part and lo and behold, it is IT!
My undying gratitude (and my husband thanks you, too!), Charlotte
