Shawn cleary
#1 Posted : Sunday, September 4, 2011 8:11:46 AM(UTC)
Shawn cleary
I have a dryer that won't heat up.I installed a new control thermostat.I have checked the thermal fuse as well as the high limit thermostat.heating element reads 14.8 ohms like the schematic specs say.I am getting 125 volts to both ends of the element and the element ohms out ok.
Can any one tell me what to check next I am baffled because I don't know if I should replace the element even though it checks out ok.
Thanks Shawn.
Tommy_28_
#2 Posted : Sunday, September 4, 2011 8:48:51 AM(UTC)
Tommy_28_
here is a link for a repair manunal this should give a few things to try. it has helped me in the past. hope i can help....
https://www.whirlpool.com/digita...0Guide%20-%208528324.pdf
