cdicioccio
#1 Posted : 16 years ago
cdicioccio
I Have A G.e. Refrigerator That Leaks Inside And The Water Settles At The Bottom Of The Refrigertor Floor. I Don't Know How Where The Water Is Coming From. When It Fills Up At The Bottom It Leaks In Front On The Kitchen Floor. How Can I Stop This From Happening
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer
