I have a kenmore elite dishwasher. The normal light keeps blinking and will not go off unless I cut the power to it. I have pulled the grey ribbon out and reconnected it. This resets it and it will run for one load and then back to blinking again. This has been very frustrating. Can someone tell me what to do next or what part i need to order. Thank you!
same problem. Check fuses, thermostats, and heating element.. 1 is probable bad
