mkillian
#1 Posted : Saturday, September 3, 2011 11:20:04 AM(UTC)
mkillian
If I have a full load and/or go to the heavy cycle my washer will not cycle to the spin/rince cycles, I have to manually turn the selector and then it will finish.
But, If I go with the light cycle and use small loads it cycles to the end without a problem.
sidfink43
#2 Posted : Sunday, September 4, 2011 12:56:27 PM(UTC)
sidfink43
Since it operates correctly in one cycle, this suggests there is not mechanical issue and that the problem is with the timer.
Change it out and you should be fixed.
