Groups ready for retrieval: Registered
I NEED HEELP ! The Washer Don't Spin, But Drain The Water And It Makes A Noise On The Transmission. I Replaced The Brake Rotor And Some Parts Tub And Seal Kit. I Tested Again And Still The Same.
Hello. Check and make sure the thrust bearing is releasing the brake assembly correctly. You can check this by turning the pulley by hand from under the washer. If the thrust bearing is not releasing the brake assembly, replace the thrust bearing. If it is releasing the brake, and the tub does not spin, you will need to replace the transmission. Hope this helps.
Found source of smell.....burned out start capacitor. REplaceced capacitor and while at it, coupling too as it was going bad.
All working fine now.:)
Great Job!!! Glad you got it going!!!:) :) :)
