bquestions
#1 Posted : Monday, April 6, 2009 6:06:46 PM(UTC)
bquestions
Where is a good place to look up the timing diagram
for the normal wash cycle?
(Kenmore 665-16933000)
The cycle doesn't advance as fast as the wall clock, I want
to determine if there is a particular spot in the cycle
where it is spinning its wheels.
#2 Posted : Tuesday, April 7, 2009 6:16:22 AM(UTC)
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208524517.pdf
It will not keep up to the wall clock as there are wait times while it heats up the water etc.
