johnh57
#1 Posted : Friday, September 2, 2011 9:27:51 AM(UTC)
johnh57
I think the washer dates from about 1995.
The washer will not agitate or spin on a slow setting (4 position wash cycle switch). I replaced the wash cycle switch - but it is doing the same thing. It works fine on fast spin and fast agitate. There is no sound at all from the motor when the cycle switch is set to a slow setting. I'm thinking it is the timer - but would like to be sure before dropping a $100 plus on a 15 yo washing machine.
I disconnected the wiring harness connecters at the timer there were no burned / corroded connectors.
John
magician59
#2 Posted : Friday, September 2, 2011 9:38:44 AM(UTC)
magician59
Sounds like the slow speed winding on your motor may be bad.
johnh57
#3 Posted : Friday, September 2, 2011 10:31:10 AM(UTC)
johnh57
thanks, I was worried that might be the case. Is there a "simple" way to test the motor windings?
John
johnh57
#4 Posted : Friday, September 2, 2011 6:44:48 PM(UTC)
johnh57
I found a diagnostic aid on checking the motor continuity. unplugged with the harness removed from the motor - the low voltage side reads something like .4 ohm on a 10x scale - so around .04 ohms. the high speed reads slightly less at about .3 on the 10x scale (so .03). It's a cheap analog meter so I don't know if the values mean anything or not. The meter is not showing open - but it's not totally shorted out either.
Also, I plugged the unit in with the cabinet off (and the lid switch disconnected) there is no voltage reading from orange to white /w black stripe, nor from violet to white with black stripe.
so am I back to the timer?
update: took off the cabinet, cleaned everything, put it back together - works fine, yea! Of course I still have no clue what the initial trouble was - there is slight discoloration on the wiring harness connector to the motor near the orange wire - it may be that all it needed was to clean those contacts by working the connecter a couple of times, idunno.
magician59
#5 Posted : Saturday, September 3, 2011 1:00:11 PM(UTC)
magician59
I originally suspected the timer; but something in your original post made me think otherwise. Keep watching it and let us know your progress. Well done!
