AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Kenmore dryer heat stays on and drum doesnt turn
My Kenmore dryer worked last night and this morning the heat element was on with the door open and when you shut the dryer door and push the start button the drum doesnt turn and it doesnt sound like the motor is running. The heat element did turn off when I turned the timer to the off position.
Originally Posted by: Trimmy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My Kenmore dryer worked last night and this morning the heat element was on with the door open and when you shut the dryer door and push the start button the drum doesnt turn and it doesnt sound like the motor is running. The heat element did turn off when I turned the timer to the off position. ...also, the drum does not move easily when I try to turn it by hand.
Dryer Repair
