Water not coming from door dispenser and water not flowing to ice maker. How do I KNOW THE DUAL WATER INLET VALVE needs replacing?
When you try to get water you should be able to hear the inlet valve click. If it does,take the water line off of it and see if water comes out when you try to get water. It could be stopped up where the line comes into the valve.
