jeffmaaske
#1 Posted : Wednesday, August 31, 2011 5:30:21 PM(UTC)
jeffmaaske
Dryer runs, but has no heat. Timer will not advance using "Automatic". However, it will advance under "Timed". Neither cycle has heat.
Based on some other posts, I suspect the solenoid coils. Is this correct, or should I do something else first.
jeffmaaske
#2 Posted : Monday, September 5, 2011 4:04:55 PM(UTC)
jeffmaaske
Purchased the solenoid coil kit. Installed them in 10 minutes. Problem resolved.
