HELLO, I'M HAVING TROUBLE LOCATING THE PROBLEM WITH MY OVEN. IT DOESN'T TURN ON AND IT DOES NOT READ ANYTHING ON THE DIGITAL PANEL. THE BURNERS ON TOP WORK PERFECT. WHAT CAN THE PROBLEM BE? GIVE ME SOME FEED BACK PLEASE. I'M PULLING MY HAIR OUT. THANKS LUIS :confused: MAGIC CHEF OVEN MODEL# S 64H-4TKXW
Groups: Expert
Most likely a bad control board.
Is it possible that the igniter has something to do with it. The clock on the panel works fine, but when i press the bake button, nothing happens??:confused:
