tweety
#1 Posted : Sunday, April 5, 2009 10:43:24 AM(UTC)
tweety
Any help would be great. My oven doesn't come on at all. The controls on the touch pad work just fine, the stove top works also, the elements never heat up even though the controls say they are on and warming up. The broiler does the same thing, set it to broil, says it's broiling and the elements is cold. There was never a "error code" that came up, working one day, not the next. Afriend checked the elements with a meter and said they are good, is it really going to be the control/touch pad panel????? Thanks Tweety
#2 Posted : Monday, April 6, 2009 3:13:02 AM(UTC)
Replacement parts for FRG GLEF396CSB | AppliancePartsPros.com
Here is a wiring diagram and a tech sheet
ftp://ftp.electrolux-na.com/Pr...pringfield/316255317.pdf
ftp://ftp.electrolux-na.com/Pr...ingfield/316259183en.pdf
I would check the temperature probe/sensor but the unit should have given an error code.
Check the wiring as the bake and broil do use a common return wire.
Be sure to unplug the unit when doing this.
The only other thing you can do is check to make sure everything is OK with the 240 volts going to the board. I do not recommend you do this unless you have some experience using a meter and working on appliances. The unit runs on 240 volts which is very dangerous.
If all OK then odds are high that it is the control board.
I did notice that the board is listed as F20, often it means the board has been updated.
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 10/20/2016 5:40:57 PM(UTC)
Oven not working (Oven Repair (including Ranges and Cooktops))
by Drekulviiin 7/1/2016 2:30:59 PM(UTC)
Oven Not Working, But Stovetop is (Oven Repair (including Ranges and Cooktops))
by Optical24 11/30/2015 11:32:34 AM(UTC)
by samsanwoo 11/7/2015 7:18:38 AM(UTC)
Samsung induction range oven not working (Oven Repair (including Ranges and Cooktops))
by Wolf22 8/4/2015 12:11:42 PM(UTC)
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
by tcockerhambuilds@cox.net 5/29/2015 2:47:01 PM(UTC)
Thermador Double Oven not working properly (Oven Repair (including Ranges and Cooktops))
by rxrep 12/28/2014 10:32:11 AM(UTC)
Frigidaire oven not working (Oven Repair (including Ranges and Cooktops))
by mommytina 12/9/2014 5:32:46 AM(UTC)
