jfdunlap
#1 Posted : Sunday, August 28, 2011 4:02:52 PM(UTC)
jfdunlap
There is no air blowing from the outside bottom of the fridge. The magnetic gaskets around the door and where they close to the frame is SUPER HOT. I have vacuumed the coils out from underneath the fridge, but still has not caused that fan to come back on. The inside still seems to be working fine...for now. :( PLEASE HELP...I cannot afford a fridge right now.
#2 Posted : Monday, August 29, 2011 2:40:13 AM(UTC)
Replacement parts for ED22DQ models | AppliancePartsPros.com
As you can see your model number is missing several digits so I cannot look up any technical data.
If the evaporator fan in the freezer is running I believe the condenser/compressor fan should also be on as they are wired in parallel.
You can check the condenser fan by measuring the voltage across it. If it has 120 volts and is not running, it is toast and needs replacing.
Or just assume it is toast and replace it if the evaporator fan is on.
