bill franklin
#1 Posted : Saturday, April 4, 2009 1:01:27 PM(UTC)
bill franklin
fresh food door top end cap is broken and need replacement. But available options are not the same part. Per the diagram it should be part 1002. However while the broken part does have 2 holes in the top - and 2 on the sides, the elbow bends to the left. In the picture it bends to the right. Apparently the part has been updated, part in comparison to my broken part it is too small.
One difference might be that my refrigerator has installed an optional front wood panel. Would different trim kits come with the paneling and do I then need to be looking into a completely different site instead of GE refrigerators?
#2 Posted : Sunday, April 5, 2009 2:54:50 AM(UTC)
Replacement parts for GE TNX22BACALWW | AppliancePartsPros.com
If your door has been installed on the opposite side then it would be 1001.
This may be part of the panel kit, could not find a shipping list for the kit so do not know. In any case if it is too small then the previous answer does not help you.
No I think you are stuck with GE.
I assume you have the original manual or have downloaded it from the GE site. Unfortunately it does not give much info on what is included with a panel kit.
I believe your panel kits are TKP22ACBB (black) or WW (white). Could not find anything on a wood panel kit.
Call GE maybe they can supply you with a ship/parts list.
Replacing pantry drawer end cap (Refrigerator & Freezer Repair)
by abcd7878 4/4/2014 12:51:48 PM(UTC)
end cap replacement on oven top (Oven Repair (including Ranges and Cooktops))
by rayandlynnbr@att.net 3/15/2011 6:27:41 AM(UTC)
Help removing end caps to access control panel (Oven Repair (including Ranges and Cooktops))
by vroosh 11/29/2010 1:09:22 PM(UTC)
My first time the newer end caps on 70 series washer (Washer Repair)
by splash4321 11/9/2010 7:09:51 AM(UTC)
Remove end caps on upper dishwasher rack (Dishwasher Repair)
by Jenny Buehler 11/24/2008 1:11:08 PM(UTC)
