greg2012
#1 Posted : Saturday, August 27, 2011 6:54:45 AM(UTC)
greg2012
What's causing my fridge to leak water on the floor?
#2 Posted : Monday, August 29, 2011 4:53:42 AM(UTC)
Replacement parts for FRIGIDAIRE FRS6LR5EM0 Frigidaire/refrigerator | AppliancePartsPros.com
Check that the drip pan (Item 26 in Section 6) under the unit is not overflowing or cracked.
Sounds like drain tube is plugged so that the water from the defrost cycle cannot drain into the drain pan. Also could be that it is frozen.
I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tral after you are done.
Be sure to unplug the unit while doing this.
May also be fro the ice maker so check the hook up etc.
