Oh Es Eye
#1 Posted : Friday, August 26, 2011 1:42:03 PM(UTC)
Oh Es Eye
The washer fills, drains, spins. It will not agitate on a slow setting though. It has a 2-speed motor and when you have the agitator setting on slow it won't start up. Spin will start on slow or fast no problem. If you turn the agitator to fast it starts up fine, and THEN if you turn it back to slow, it will slow down and still works fine.
· Agitator won't start if on slow
· Agitator starts on fast and once it's started can be set to slow
· Spin starts on slow or fast with no problems
· When the agitator doesn't start up there are NO noises. (motor, transmission, buzzing)
sidfink43
#2 Posted : Sunday, August 28, 2011 10:58:39 AM(UTC)
sidfink43
If this model has a speed selection switch I would try changing that out, and if that does not fix things then try changing out the timer.
