Carlos Peres
#1 Posted : Friday, August 26, 2011 9:43:57 AM(UTC)
Carlos Peres
Can no longer select different cycle lengths (other than "normal wash"). The lights on the control panel (except for the "normal wash" green light) also do not light up ("light wash", "rinse only", "start", "clean", "washing" and "drying").
I switched the breaker off for a couple of minutes, but this did not fix the problem. Any suggestions? Thanks!
Joe / APP Team
#2 Posted : Friday, August 26, 2011 1:26:19 PM(UTC)
Joe / APP Team
Carlos,
You most likely have an issue with the control panel key pads,
Part number: AP4364676
If you have access to a multimeter, you can verify the button operation, using the tech sheet( attached to the backside of the kickplate assembly and the meter to verify you get a circuit when the button is pressed.
Heres some meter usage information:
Good Luck,
