Ice maker not working. I can see ice in the maker but it has not fell out. I thought it could be froze up, does that happen? I can feel the ice with my fingers and I can also see it, can move it around with a tool but it has not fell out.. How exactly does the maker work?
Water in door working good
whrilpool had a bad icemaker design pull the white cover off the front and see if the white gear will move either way or come off it is broke replaced ice maker
white gear is not broke and turns by itself
Groups: Expert
Replace icemaker. gear should not turn by itself.
the problem is in the bi-metal inside the ice maker ,what happened is that the bi-metal didn,t close when it got cold in the freezer section,this caused the heater not to work, causing the ice in the ice maker not to let go in the trough, that why you can see the ice in the ice maker.
