My timer will not advance with the Hi-Temp wash and rinse options in the "ON" position. I've checked: 1.) Resettable thermostat Part Number: AP2109201 made by FRIGIDAIRE 2.) Heating element Part Number: AP4424048 made by FRIGIDAIRE Both have continuity. I've traced the option wire to two parts on the bottom right of the dishwasher. They look similar in appearance to the resettable thermostat found on the bottom left. One is connected to an orange wire and the other is connected to a yellow/black wire. I cannot find these parts in the diagram. Does anyone know what these parts are and are they likely my problem? Thanks
THIS FORUM IS DEAD!!!!!!! |
