lewiada
#1 Posted : Wednesday, August 24, 2011 7:58:36 AM(UTC)
lewiada
Hi all,
Last week my freezer had frost all over it and the fridge was warm. I figured this to be a classic case of ice building up, so I defrosted the freezer (manually). Since this happens often, I also did a continuity test on the Defrost heater, hoping this was the issue since it's a simple fix to replace. But no, the Defrost Heater worked great registering a steady 34 Ohms on the multimeter.
Anyway, I put the freezer back together again, assuming that the frost would come back, but at least the fridge would cool off again. No such luck. Now even the freezer isn't freezing (my ice cubes are all melting).
So what's next in the debug process?
tx!
adam
Joe / APP Team
#2 Posted : Wednesday, August 24, 2011 8:29:13 AM(UTC)
Joe / APP Team
Originally Posted by: lewiada Go to Quoted Post
Hi all,
tx!
adam
Adam,
Did you check the defrost thermostat for an open or closed circuit (open circuit at room temperature, closed circuit below 35 to 40 dgrs). are you sure you have all the wires properly seated and attached, you didn't knock anything loose, etc.? You could have an issue with the defrost timer or ADC board(Adaptive Defrost Control) Depending on the model number(You forgot that), get us a model number and we can verify your defrost system, and advise you from there.
lewiada
#3 Posted: : Wednesday, August 24, 2011 8:33:11 AM(UTC)
lewiada
Hi, sorry I forgot the model number. It's KTRP20KDAL 02. Best I can tell nothing came loose ... I double checked everything before I put it back together. Something is definitely wrong cause as I mentioned, I go through this process about once a month. But this is the first time it didn't go back to being cold ...
Joe / APP Team
#4 Posted : Wednesday, August 24, 2011 10:47:27 AM(UTC)
Joe / APP Team
Ok then,
Thanks for the Model number and better explanation. Based on the new information, Replace the defrost timer
Part number: AP2984369
located inside the refrigerator control panel. Thats the more likely issue at this point.
lewiada
#5 Posted : Wednesday, August 24, 2011 11:02:48 AM(UTC)
lewiada
Thanks, but is there a way to test this before ordering? I'd hate to spend $45+shipping on part and then find out that it wasn't the problem.
tx!
adam
Joe / APP Team
#6 Posted : Thursday, August 25, 2011 6:14:16 AM(UTC)
Joe / APP Team
tx!
adam
Adam,
Here is the defrost timer circuits and test procedures.
Being an intermittent problem, I hope something shows up for you.
Disconnect all wires from the timer and attach ohmmeter probes to the terminals specified in the accompanying chart. If no continuity is indicated, the timer is defective.
To Test Turn Timer Knob to Check Between Terminals
Timer Motor Cicuit Leave as is 1 & 3 (black to red)
Defrost Circuit 1st Click 1 & 2 (black to pink)
Compressor Circuit 2nd Click 1 & 4 (black to orange)
You can also run Voltage checks from the timer terminals to chassis ground, if needed to verify power in and out of the timer assembly, then move the the individual components using the same method.
Freezer and fridge not cooling correctly any more (Refrigerator & Freezer Repair)
by terry martin 8/19/2016 2:32:26 PM(UTC)
LG Freezer AND Fridge not cooling (Refrigerator & Freezer Repair)
by losewithmolly 8/8/2015 5:59:43 AM(UTC)
GE profile PSC25MSTASS freezer and fridge not cooling (Refrigerator & Freezer Repair)
by Drizo5488 6/17/2014 4:53:22 PM(UTC)
bottom freezer and fridge not cooling (Refrigerator & Freezer Repair)
by manicmech 6/9/2014 11:38:40 AM(UTC)
Iced behind freezer back panel. Freezer and Fridge not cooling, temp around 50F (Refrigerator & Freezer Repair)
by guanacux 1/21/2014 8:22:15 PM(UTC)
by BamBam717 1/13/2014 3:48:33 AM(UTC)
by jape_ringgold 8/21/2013 7:50:31 PM(UTC)
GE freezer and fridge not cooling all they way (Refrigerator & Freezer Repair)
by wmchuck 8/2/2013 6:05:13 PM(UTC)
Freezer and fridge not cooling (Refrigerator & Freezer Repair)
by ricky1842 10/25/2012 7:14:19 AM(UTC)
MSD2758GEB Freezer and Fridge not cooling properly (Refrigerator & Freezer Repair)
by KFish 3/15/2012 8:50:55 PM(UTC)
GE Freezer and Fridge Not Cooling Suddenly (Refrigerator & Freezer Repair)
by toocool1 9/13/2011 7:22:44 PM(UTC)
by Eureka 7/27/2011 12:02:30 PM(UTC)
Freezer and Fridge not cooling (Refrigerator & Freezer Repair)
by EdP 3/25/2011 8:34:25 AM(UTC)
GE Freezer and fridge not cooling enough (Refrigerator & Freezer Repair)
by terrynow 9/22/2010 12:22:33 PM(UTC)
Freezer and Fridge not cooling as it should (Refrigerator & Freezer Repair)
by hgiljr 11/11/2009 4:15:14 PM(UTC)
