I have amana refrigerator,that's 20 years old. We like this machine very well, but I have a problem. It defrosts every 6 hours for twenty minutes, then when it starts the fans come on but the compreesor over load kicks out about 6 to 8 times, befor the compressor starts. I measured the amps on attemting start up pulls 20 amps for about 2-3 seconds, kicks out the rest of the time it starts runs fine. So far I replaced the starting cap. Help, my wife really likes this thing. Thanks, Wayne
Hello Wayne,
I also love my 20 years old Amana BC20JL model. This really was/is a great and reliable machine. So far I never had any problems except now. The outside and inside looks like brand new.
I have a very similar problem like you described:
About every 28 seconds a relay engages followed by one (1) beep. After 2 seconds the relay drops with another beep. This cycle repeat itself every 28 seconds. What is working is the fan, which is continuously on. Also, I think it's called the "door defrost" is working. I used a watt meter and checke the following: fan running 56 watts; fan + "door defrost" uses 181 watts.
Any help would be very much appreciated.
Thanks in advance, karlheinz
