andysicko
#1 Posted : 16 years ago
andysicko
Ice maker started by not releasing the cubes from the tray and then refilling the tray. Replaced the tray and the support part as well. It now seems like the tray is turned over and jammed up. Do I need the whole motor assembly? What does the sensor sense? I am suspicious if this may be contributing. Thanks
#2 Posted : 16 years ago
I would recommend to replace the whole ice maker assembly.
- The part number for the ice maker assembly is AP4167888
Here are the break down diagrams and Replacement parts for MAYTAG RS2555SL | AppliancePartsPros.com
