dwu
#1 Posted : Thursday, April 2, 2009 10:59:04 AM(UTC)
dwu
Hello,
I found this part is available, but I wonder is it difficult to replace the door switch for this fridge ? I was under the impression that the liners are filled with foam after parts are put in, making it difficult to access the parts.
Anyway, I open the door and no light comes on and the switch has lost its spring so I figured I'd start with the switch.
Can I access the switch by removing a side panel or do I pop the switch out from inside (the liner - it seems fit too hard to do that ) ? Is it easy ?
Thanks & please advise.
woodchuckie
#2 Posted : Thursday, April 2, 2009 12:10:40 PM(UTC)
woodchuckie
It just pops out with a small screwdriver. Looking at the picture there is a clip on the side of the new one which holds it in place when you put it in.
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
Door switch replacement (Microwave Repair)
by pilotlite 10/1/2013 7:55:01 AM(UTC)
Help with GE Spacemaker Door Switch Replacement (Microwave Repair)
by ssgmail 2/24/2013 9:54:34 AM(UTC)
Affinity door switch replacement (Washer Repair)
by nancybillj 2/6/2013 7:32:59 AM(UTC)
dryer door switch replacement (Dryer Repair)
by noto 6/1/2011 6:42:10 AM(UTC)
Dryer door switch replacement (Dryer Repair)
by BK1 4/24/2011 12:09:17 PM(UTC)
Door Switch Replacement (Dryer Repair)
by gardijon 5/10/2010 2:59:04 PM(UTC)
