Steve623
#1 Posted : Thursday, April 2, 2009 9:08:45 AM(UTC)
Steve623
Both refrigerator lights are out. I've replaced the bulbs, although the original bulbs were good, turned the circuit on & off, to see if circuit problem and still the light do not go on. The rest of the unit is fine. Could it be the switch & how do I change it?
woodchuckie
#2 Posted : Thursday, April 2, 2009 12:20:00 PM(UTC)
woodchuckie
The switch will pop out with a small screwdriver. Connect the two wires to bypass the switch and see if the light works.
Steve623
#3 Posted : Thursday, April 2, 2009 1:07:10 PM(UTC)
Steve623
Thanks for the help, I'll give it a try.
