kwan
#1 Posted : Thursday, August 18, 2011 8:37:39 AM(UTC)
kwan
When I turn any of the knobs to the "Light" position, there is no clicking noise and, although the gas is coming through, there is no spark to actually light up the fire. I've had to use matches / a lighter in order to get the fire going. I'm trying to fix it, but I'm not sure what the problem is.
Joe / APP Team
#2 Posted : Thursday, August 18, 2011 11:59:25 AM(UTC)
Joe / APP Team
Kwan,
You most likely have a bad spark module, or broken wire.
I can't verify that, or assist you with a part number, due to an improper model number. Could you get us a proper model number off the production plate of the unit, so we can better assist you.
Thanks,
kwan
#3 Posted : Friday, August 19, 2011 4:24:56 PM(UTC)
kwan
Sorry, the correct model number is: CGS980SEM1SS
Joe / APP Team
#4 Posted : Monday, August 22, 2011 5:27:17 AM(UTC)
Joe / APP Team
Kwan,
Here are some part numbers you may need, once you start your checks,
Part number: AP3792393
Part number: AP4344337
Once you get the range out and the cooktop up, to access the wiring and module, you'll be fine, and have it figured out in no time.
Good Luck,
kwan
#5 Posted : Friday, August 26, 2011 7:58:17 AM(UTC)
kwan
Hi how can I get access to the spark module on the G.E. Cafe stove model# CGS980SEM1SS, is it on the top?
Thanks!
Kwan
650-270-3782
Joe / APP Team
#6 Posted : Friday, August 26, 2011 1:52:15 PM(UTC)
Joe / APP Team
Thanks!
Kwan
650-270-3782
Kwan,
There are two possible locations
One location is in the back of the unit about 1/2 way down from the top on the right side.
If the spark module is under the top, you will need to remove the grates, drip pans and burner caps, remove the two screws that hold the base to the cook top, and carefully lift the burner base away from the cooktop and disconnect the igniter wire. You can then lift the top off the range , using a putty knife or flat bladed tool to press in on the spring clips to release it.
You may find it a bit easier if you label all the caps , burners and wires as you remove them, so you can easily re install all the components in the proper location.
Good Luck,
