rosygt
#1 Posted : Wednesday, April 1, 2009 1:54:05 PM(UTC)
rosygt
After a wash cycle they soapy water is discharged and it is free-flowing down the lower front of the machine right next to where the wire harness enters the base of the machine. It does this after the clean cycle and then the rinse cycle.
applianceman
#2 Posted : Wednesday, April 1, 2009 5:21:51 PM(UTC)
applianceman
This sounds like a soap problem, either a small amount of non-dishwasher detergent has accidentally entered the washer or your using one of those 3-in-1 action packs. If you are using the 3-in-1 action pack stop and see if the leak goes away because I have seen this kind of soap cause dishwashers to leak a lot. Dishwasher Leaking Repair Guide
#3 Posted : Thursday, April 2, 2009 12:58:39 AM(UTC)
You can dump in a gallon of vineger to remove the soap and foam.
#4 Posted : Thursday, April 2, 2009 4:30:31 AM(UTC)
Here is the parts breakdown
Model Search
Open the unit up half way through a wash cycle
Check for suds. A little bit of froth is normal but if you have suds then it is a soap problem.
Check that all the holes in the spray arm are clear. Sometimes you can get a partial plug and it will spray at a weird angle and cause a leak.
Check that the filter on the tub floor is laying flat. Again sometimes it can redirect the water and cause a leak.
Check that the water is actually leaking out of the tub or is it leaking out of the door's outside panel
Check #49 in the Door section of the above parts breakdown.
See the following at TechnicianBrian's website
Model Search
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
Dishwasher leaking from motor area (Dishwasher Repair)
by jay143 11/1/2016 12:20:29 PM(UTC)
Dishwasher Leaking (Dishwasher Repair)
by alanwoodbury 9/26/2016 10:47:47 AM(UTC)
whirlpool dishwasher leaking from door (Dishwasher Repair)
by pburd89 2/19/2016 1:36:17 PM(UTC)
Kitchenaid dishwasher leaking (Dishwasher Repair)
by steve80124 9/21/2015 2:15:04 PM(UTC)
Dishwasher leaking from sides and detergent sometimes solidified (Dishwasher Repair)
by luked3 4/9/2015 7:03:05 AM(UTC)
dishwasher leaking from bottom (Dishwasher Repair)
by kjack45 12/8/2014 8:06:43 AM(UTC)
