Ice maker will not desperse ice, blue light is blinking. Ice is in the ice maker, I have shut of the ice maker and tried to restart it. Checked the water volume and it is ok.
Rank:: Advanced Member
Originally Posted by: boat1 ...Ice maker will not desperse ice, blue light is blinking... If you meant the LED status light on the ice maker than the ice maker has gone bad. - The part number for the ice maker is AP4345120Gene.
Gene it is not the LED light. The light is above the on/off switch in the freezer and on the side of the ice maker. I shut the ice maker off for a couple of minutes the light will stay on for awhile.
thanks boats
Does the ice maker have a green LED status light? If it does then what it shows? What is the temperature in the freezer?
Green light on side of ice maker, freezer temp is 0. The green light comes on when I turn the ice maker on and starts flashing after several minutes.
Originally Posted by: boat1 ...The green light comes on when I turn the ice maker on and starts flashing after several minutes... It's indicating the faulty ice maker. It has to be replaced. Gene.
