Marke47
#1 Posted : Tuesday, March 31, 2009 3:53:07 PM(UTC)
Marke47
The ice maker on my Frigidaire refrigerator #PLHS69EGSS1 will only give out crushed ice even though the cubed light is on.
TechnicianBrian
#2 Posted : Tuesday, March 31, 2009 5:58:20 PM(UTC)
TechnicianBrian
Sounds like you may have a sticking solenoid. I wrote about this failure in my post Frigidaire Refrigerator Ice Dispenser Problems which gives a basic description of how the unit works and the potential failures. Give it a read and see if it helps.
Digtheblues
#3 Posted : Wednesday, August 4, 2010 1:41:33 PM(UTC)
Digtheblues
I have this same problem and can feel that the solenoid behind the cover that is supposed to trigger the flap is moving freely. The question is how do you gain access to that solenoid? I'm hoping that the entire ice maker doesn't have to be removed to get behind that cover.
fstdrvr2
#4 Posted : Wednesday, March 7, 2012 7:55:13 PM(UTC)
fstdrvr2
Solenoid was bad (Plastic Melted). After replacing, still did not dispense Cubes. Voltage check shows a constant 50vac to solonoid even when not dispensing, probably why original burned out. Looking at print, should be dispenser board, but not sure. Anyone seen this one?
Rajkalex
#5 Posted : Wednesday, August 21, 2013 7:13:45 PM(UTC)
Rajkalex
I came here after experiencing the same issue though I haven't checked the voltage since replacing it. Of course, no one responded to your problem. Were you able to figure it out?
fstdrvr2
#6 Posted : Thursday, August 22, 2013 8:09:06 AM(UTC)
fstdrvr2
After replacing the expensive front control board, it still had the same problem. Fortunately it was in a rental home and the owner told the tenant to just live with crushed ice. I unplugged the wires to the solenoid to keep it from burning up too. The only part I didn't try was the control board in the back. If it fixes the problem for you, please let me know. I have a lot of $$$'s invested in this unit, with no return.
