heathajo
#1 Posted : Tuesday, March 31, 2009 1:02:03 PM(UTC)
heathajo
I had a dishwasher installed about a year in a half ago and it has never really worked correctly. It does not go through the entire wash cycle. It does not drain and it does not dry. Every once in a while it will complete a cycle but that is really every once in a while. I have read everything there is about what could be wrong and I have checked everything. The water temp is fine there is nothing clogged in the drain. I need help!:mad:
#2 Posted : Tuesday, March 31, 2009 3:25:07 PM(UTC)
A Model Number may help others help you!
Need more detailed info.
Does it hang up at the same point in the cycle every time, etc?
I assume it drains and dries correctly when it does complete a cycle.
This tells you that the heater and the pump are OK.
Did you remove the door's inner panel and check the connectors and wires.
Also where the wires run from the door to under the unit.
Your problem does sound like a bad connection.
It may be a poor solder joint on the control board.
GE dishwasher issues (Dishwasher Repair)
by cruisn69 7/14/2020 1:56:13 AM(UTC)
Help with Dishwasher Issues (Dishwasher Repair)
by Brutus45831 4/25/2020 4:08:39 PM(UTC)
dishwasher issues frigidaire (Dishwasher Repair)
by kentrx1 8/12/2018 1:35:02 PM(UTC)
by brandon42 12/23/2013 5:10:22 PM(UTC)
by DKNECHEL 9/1/2013 10:45:31 AM(UTC)
kitchenaide dishwasher issues (Dishwasher Repair)
by luke54 10/29/2011 12:12:36 PM(UTC)
