Fairly certain my compressor start relay is bad. Removed the relay from the compressor, but having diffuculty removing the 2 wires from the relay. They don't appear to be corroded, just stuck - as if I need to push a magic button to release them - and I don't see any buttons. They wiggle, but something's holding them in there. Thanks for your help.
Use a flat blade screwdriver and pry them off.
