Rank:: Member
I have problem with my frage it is not cooling and the compressor is not running so i change the start relay but when i put the start relay it runs for 5 sec then the start relay is sparking and it shut off i don't know if i need to change the compressor or not please help me thanks
either you got a bad relay or faulty wiring in any case you can check the comp by resistance if any pin to the case of the comp is shorted bad comp if common (which is the pin by itself) to one of the others one should read 3-4 ohms and the other should read 6-7 ohms and between the to top one (side by side) 10-12 ohms if not bad comp
