Maytag Performa makes high pitch noise.
Which cycle (wash/spin) is it in when it makes this noise?
Originally Posted by: magician59  Which cycle (wash/spin) is it in when it makes this noise? Both Cycles.:)
Tilt it back and remove the belt. Turn the pump (the smaller pulley) in both directions by hand. If it makes noise, replace it. Tell us what you find.
Today I removed the belt and turned the pump pulley and it has that "grinding" noise. I am going to order the pump this afternoon from applianceprtspros.com. Thank you "Magician59" for the advice. God bless you!
Groups ready for retrieval: Registered
Originally Posted by: sabripatri  Today I removed the belt and turned the pump pulley and it has that "grinding" noise. I am going to order the pump this afternoon from applianceprtspros.com. Thank you "Magician59" for the advice. God bless you! I just replaced mine yesterday. I waited too long to figure out what was making the loud noise and my whole washer seized up in the middle of the spin cycle and made a nice burning smell. Good thing you caught it early. Good luck.
