tponcsak69
#1 Posted : Sunday, August 14, 2011 9:29:38 AM(UTC)
tponcsak69
I have a frigidaire front load washer that quit filling with water. It won't fill on any cycle, and I have checked the inlet valve, even tried a new inlet valve and still no water. I have researched and think it may be the timer, but I have also heard that it is rare for a timer to quit all out and not work at least on one cycle or more. Any suggestions??
sidfink43
#2 Posted : Monday, August 15, 2011 4:50:29 PM(UTC)
sidfink43
Check the wiring and connections at the timer, but it sure sounds like the timer is the problem. Yes it can fail on all cycles.
