When I turn the knob to my dryer all I hear is a buzzz but the dryer won't turn on? Any thoughts? :rolleyes:
Is the buzz cominng from under the drum. May be the motor trying to start.
This may take two people. Open the door Rotate the drum, it should rotate fairly easily If not the drum is jammed on something. If OK Hold the door interlock switch closed Start the dryer and while it is buzzing, turn the drum in the correct direction Watch your knuckles as it may start up If it starts rotating probably your motor is shot |
THIS FORUM IS DEAD!!!!!!! |
