rbplatinmconst
#1 Posted : Monday, March 30, 2009 1:04:50 PM(UTC)
rbplatinmconst
Woke up this morning and my freezer temp said +4 like it should but, it was blinking and refrig temp said 36 like it should but, when I opened both sides obviously the temps were off . so I pulled it from the wall and noticed it never cycled on or off so I unplugged unit cleaned coil's , floor etc. Not as dirty as one might think!!!!!!!!!!! Plugged unit back in and temp control registered current temps of 36 and 56. All display's work but, unit click's and never cycles on for cooling. Is it a relay or sensor or circuit board!!!.
woodchuckie
#2 Posted : Monday, March 30, 2009 1:28:32 PM(UTC)
woodchuckie
Yes it does sound like the relay from your description. Part 31 on your machine compartment diagram. Replacement parts for MAYTAG RS2577SL | AppliancePartsPros.com
