The ignitors are glowing red but no gas. I read that it may be because the ignitors are not drawing enough amps and opening the gas valve.Both the bake and broiler ignitors glow red, but neither light the burner. The broiler is inside the oven,not in a bottom drawer. How can I test the ignitors. I have a probe type multi meter.
Hello scottkoch. You will test at the gas safety valve for 3.2-3.6 volts AC. If the proper voltage is there, you have a bad safety valve. If the voltage is low, you will need to replace the igniter. Hope this helps. Part number: AP4282628
