have no lights in freg work in frezer unit shuts off now and then no numbers on temp control is it the control board model #gs6shexns00
Replace the bulb,PUT ON A GLOVE AND TIGHTEN IT TIGHT!!!!!:)
If you pull the refrigerator out, and take the back bottom cover off, and next to the compressor is a white box, held in place by 2 screws. Unscrew the 2 screws and pull the box out, and inside is a electronic control board. Pull it out, and you will most likely see a burn't spot in the back. The part # is W10135090. Let me know what you find. Tom ApplianceEducator.com
