My refrigerator has water and ice in the door. The ice disp. works fine but no water will come out. I have put in a new water valve and rerplaced filter and still no water. When I push the lever I can hear a clicking sound in the rear. Can you give me some things to check or suggestions. Thank You Richard
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does try a hair dryer blowing where the water line is at the dispenser for a few minutes.
If the water doesn't come out when you disconnect it, disconnect it at the water inlet valve and try the dispenser button.
