gerardo
#1 Posted : 16 years ago
gerardo
Does not dispense water or makes ice. Water valve open. What could it be?
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Do you have a water filter to change.
When you try to get water does the water inlet valve on the back click. Disconnect the line there and try the switch. Does water come out.
gerardo
#3 Posted : 16 years ago
gerardo
The water filter is fine. there is good presure going into the fridge. There is no click
