My over the range microwave shorted from steam from cooking on the cooktop. It will turn on but not heat. I smell electrical burn behind the control panel. Does the magnetron need to be replaced? T
I would visually check the magnetron, diode, and transformer for burnt sections. The burn electrical smell points towards the high voltage section.
