Ice is building up to the extent that it interfers with he evap motor. The motor will make noise (the blades hitting the ice) for a while and then it stops, resulting in the shut down of both refridgerator and freezer. I've replaced the control kit and the evap motor and still have the same problem after about 10 days of running. Any suggestion as to how to correct the ice problem? Thanks.
