tennfly
#1 Posted : Saturday, August 6, 2011 9:32:04 AM(UTC)
tennfly
Refridge/freezer will not cool at all. The fan runs and I hear on and off clicking noises. Is it a bad compressor or a bad board?
#2 Posted : Sunday, August 7, 2011 9:12:41 AM(UTC)
Pry off the compressor side cover and check the start device, a small black plastic item AP3601983 Just take a picture of the wires to it and order a new one here.
tennfly
#3 Posted : Sunday, August 7, 2011 3:23:54 PM(UTC)
tennfly
When I get home I'll try taking the starter cover off.
How does it come off? Just pry it with a screw driver?
Thanks!
#4 Posted : Sunday, August 7, 2011 3:36:47 PM(UTC)
They usually have a wire holding it in, rather easy to pry off, but either take a picture of the wiring, or make a diagram on paper.
tennfly
#5 Posted : Sunday, August 14, 2011 3:43:43 PM(UTC)
tennfly
Ok. I have got the starter switch off the compressor. After I pried the cover off, I pulled two modules off. The one on top is brown with three terminals (part #2183454) and a white and black module on the bottom with one terminal (part # 2183456) The part #'s were taken off the modules.
Should I replace both?
#6 Posted : Monday, August 15, 2011 1:13:29 AM(UTC)
The bottom one is the overload which rarely fails, replace the upper ptc relay AP3601983 Make a diagram of the wiring to both items.
tennfly
#7 Posted : Monday, August 15, 2011 6:56:42 AM(UTC)
tennfly
Thanks. I'll order the starter relay.
By the way, the compressor was getting hot when I had the fridge plugged in, but no cooling at all. The fan ran and something (compressor?) was clicking on and off every 30 secs to a minute.
