the unit shut down during last cycle before completely finishing. none of the lights on the panel come on, i check breaker and it was not tripped. I am reading it may be the thermal fuse? or could it be something else. I replaced the panel about 6-8 months ago. Thanks.
Originally Posted by: florida1  the unit shut down during last cycle before completely finishing. none of the lights on the panel come on, i check breaker and it was not tripped. I am reading it may be the thermal fuse? or could it be something else. I replaced the panel about 6-8 months ago. Thanks. Florida, You're on the right track, If the unit is dead, you do want to start at the thermal fuse and door switches up in the control panel. Part number: AP3178588
