Maytag Stove model, MER5730AAQ oven temperature is erratic, there are "no" fault codes up the temperature varies both high and low arround the setpoint, (way beyond 20 degrees). There would be two primary causes, the oven sensor or the control unit. Without a fault code there is no sure thing, (both the bake and the broil elements work). Is there some test on the oven sensor, (RTD or thermalcouple) or the control unit without taking a shot in the dark replacing one of the two parts?
