davecjr
#1 Posted : Thursday, March 26, 2009 6:18:55 AM(UTC)
davecjr
It just stops at about the time it should start pumping out the water on the regular wash cycle. It also fails on the second rinse. If it sits for a while, an hour or more, I can raise and lower the lid and it will start again and finish normally. So far there's been no problem on the permanent press cycle. I was thinking timer, but now I think it has more to do with the pump cycle.
#2 Posted : Thursday, March 26, 2009 2:47:38 PM(UTC)
The first thing I would check is the lid switch. Possible it's not engaging properly.
Here are the break down diagrams and Replacement parts for WHIRLPOOL LSB6400KQ1 | AppliancePartsPros.com
davecjr
#3 Posted : Friday, March 27, 2009 6:12:17 PM(UTC)
davecjr
Gene,
You were right. I was trying to make it too complicated. I replaced the swiotch and am back in business.
Thanks,
Dave
#4 Posted : Friday, March 27, 2009 6:16:13 PM(UTC)
You are welcome. I'm glad you were able to fix it.
