Headhunter
#1 Posted : Thursday, August 4, 2011 6:18:32 AM(UTC)
Headhunter
On touch pad:
Heavy, Light,Rinse,Insta, Auto, Delay,ToughScrub,High Temp buttons all work fine.
Norm,Start/Cancel,HeatedDry,Sanitize will not light up
Door switches test ok. Cleaned ribbon connector.
Usually run washer on Normal then push Start.
Does the touch pad wear out? How can I test it to see if buttons are working?
Thanks, Mark
#2 Posted : Friday, August 5, 2011 2:47:34 AM(UTC)
Replacement parts for MAYTAG MDBTT70AWB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
[COLOR="DarkRed"]Does the touch pad wear out?[/COLOR]
Yes but usually the unit wears out before the switches.
But like anything else some do just fail.
[COLOR="DarkRed"]How can I test it to see if buttons are working?[/COLOR]
Yes see the tech sheet for the procedure.
You will need a meter.
The normal way to troubleshoot is to check the control pane (keypad), if it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
File Attachment(s):
MDBTT70.pdf (893kb) downloaded 7 time(s).
