I'm having a little trouble identifying the right part for my side-by-side fridge. I've searched the forums and know that my door cam broke and caused the issue I am currently having (door used to pop, now hard to close, it will seal...but easily pops open, actually saw pieces of the cam breaking off over the course of 3 weeks). I took a picture of the appliance sticker inside the fridge part. I think the model number is P/N 241516673, but it doesn't come up in the part search function so I feel like my picture doesn't show the info I need. ![UserPostedImage](http://file:///C:/Users/ccurrier.YELLOWSUBMARKET/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/6QHT4XQK/photo%20%286%29.JPG) ![UserPostedImage](https://lh4.googleusercontent.com/-sMmAnmkPAYQ/Tjlar38v_WI/AAAAAAAAAFY/pql_byX1QV4/w500-h375-k/fridge%2Binfo.JPG) It seems as though Part Number: AP2115808 is what I need. Can someone confirm? Also - it looks like both the top and bottom hinge/cam have broken away. Do I need to order two pieces or do they come as a unit? Thanks for helping!
The part number on that label may well be the part number of the label. Check is other areas for the actual model number. Model Number Locator |
THIS FORUM IS DEAD!!!!!!! |
I found what I needed. Both in terms of the model number and then a confirmation of which part I needed. Order is placed and I'm now on step 2 of fixing my door. Thank you!
