Hi! need help some guy hit phone pole and power went out. 8hr later power turned on.Everything in the house works but refrigerator checked breaker its good.Checked outlet good also. checked power down to control board good. need help any reset switches any where? thanks tomfordtnt@hotmail.com
help out of warranty Originally Posted by: ispan  Hi! need help some guy hit phone pole and power went out. 8hr later power turned on.Everything in the house works but refrigerator checked breaker its good.Checked outlet good also. checked power down to control board good. need help any reset switches any where? thanks
Most likely the problem is a bad PCB on the back of the refrigerator (#5 on the diagram), but there is a small chance for the front display board to be bad as well. - The PCB Part number: AP4137443
Originally Posted by: Gene  Most likely the problem is a bad PCB on the back of the refrigerator (#5 on the diagram), but there is a small chance for the front display board to be bad as well. - The PCB Part number: AP4137443
thanks for info Gene i change the main power board assy with good one still dont work also checked the 2 thermal fuses they are good.still dont work i think it mite be the transformer i see it has a fuse in it how to test? Tran powe part# ap4138312 old # new # ap4136389
Just check all windings for continuity.
